Sruk
4 months agoBrand new USB-BLASTER 3 issues
A day ago I received a brand new and very expensive USB Blaster III from DigiKey with the following Serial Number: UB3000432 I have an issue using this device. The device is visible both in Win11 De...
- 4 months ago
Engineering sample means that the part is pre production and not suitable for industrial use. So one of the early production batches for engineers to play with and get used to the new board.
Considering your troubleshoot, I will request a replacement shipment from Customer Resolution team.
DigiKey
Zvi
4 months agoHi Sruk,
In case you use the adapter for 2.54" pitch header through the provided adapter, the pinout is the same as it was before.
But what happens in case the developed board contains 1.27" pitch connector? and you connect it directly without the adapter?
According to the User Guide, in this case the pinout is different.
