Board Test System–Stratix 10TX Development Kit
Hi everyone, I’m working with the Stratix 10 TX Signal Integrity Development Kit (DKSI1STXEA) on a Windows PC.
I have followed the installation steps provided in the documentation and installed the development kit software/package as instructed. However, after completing the installation, I still cannot find the Board Test System (BTS) files.
According to the user guide, I expected to find something similar to:
<package_dir>\examples\board_test_system\BoardTestSystem.exe
I have not been able to locate the associated .sof test designs either. Has anyone successfully installed and used the BTS for this development kit?
Could someone please clarify which package needs to be installed to get the BTS files, or where these files are located in the current version of the development kit software?
Board: Stratix 10 TX Signal Integrity Development Kit
Kit: DKSI1STXEA
Host OS: Windows
I have already followed the documented installation procedure, but the BTS files still appear to be missing. Any help would be appreciated. Thank you!
Same post, different user?
I linked to the installation files in the other post. All the files you mention are visible by just unzipping. There's a .zip inside the main .zip if that helps.
- AhmadAftab
Hello AqidAyman_Altera , thank you for the response.
Could you please clarify how can I launch the Board Test System (BTS) shown in the Stratix 10 TX SI Development Kit User Guide, so that I can check the board connection/status ?
- AqidAyman_Altera
Hello AhmadAftab,
Here are the steps to launch the BTS on your Stratix 10 TX SI Development Kit:
Prerequisites
- Before running the BTS, open Quartus Prime software to automatically set the environment variable $QUARTUS_ROOTDIR.
- The BTS uses this environment variable to locate the Quartus Prime library.
- Because the BTS is designed based on the Quartus Prime software, be sure to close other applications before you use the BTS.
- The BTS cannot run correctly unless the USB cable is attached and the board is powered on.
Launch Steps
- Connect the Altera FPGA Download Cable from your PC to the board.
- Make sure SW5.1 is set to the ON position and power up the board.
- Launch the BoardTestSystem.exe file, located at
\examples\board_test_system.
As you can see from the BTS GUI screenshot you shared, once everything is connected correctly you should see "Board Connected" in green at the bottom.
- AhmadAftab
Yes and Thank you,
I found the zip files and follow the guidelines, but still struggling to find the main the page in order to work on the next steps.
This is what I am looking for in order to connect the board.
- AqidAyman_Altera
Great that you've got the zip files sorted!
If you can share what specific step is blocking you (e.g., JTAG not detected, BTS GUI not launching, clock not locking), I'm happy to dig into that with you.
- AqidAyman_Altera
Hi Ahmad,
Please confirm if you have found the BTS files or not. As mentioned by sstrell, it should have in the installation file linked in the other post.
Aqid
- sstrell
