AhmadAftab
2 months agoBoard Test System–Stratix 10TX Development Kit
Hi everyone, I’m working with the Stratix 10 TX Signal Integrity Development Kit (DKSI1STXEA) on a Windows PC. I have followed the installation steps provided in the documentation and installed the ...
- 2 months ago
Same post, different user?
I linked to the installation files in the other post. All the files you mention are visible by just unzipping. There's a .zip inside the main .zip if that helps.
AhmadAftab
2 months agoHello AqidAyman_Altera , thank you for the response.
Could you please clarify how can I launch the Board Test System (BTS) shown in the Stratix 10 TX SI Development Kit User Guide, so that I can check the board connection/status ?
AqidAyman_Altera
1 month agoHello AhmadAftab,
Here are the steps to launch the BTS on your Stratix 10 TX SI Development Kit:
Prerequisites
- Before running the BTS, open Quartus Prime software to automatically set the environment variable $QUARTUS_ROOTDIR.
- The BTS uses this environment variable to locate the Quartus Prime library.
- Because the BTS is designed based on the Quartus Prime software, be sure to close other applications before you use the BTS.
- The BTS cannot run correctly unless the USB cable is attached and the board is powered on.
Launch Steps
- Connect the Altera FPGA Download Cable from your PC to the board.
- Make sure SW5.1 is set to the ON position and power up the board.
- Launch the BoardTestSystem.exe file, located at
\examples\board_test_system.
As you can see from the BTS GUI screenshot you shared, once everything is connected correctly you should see "Board Connected" in green at the bottom.
