15 years ago
BeMicro SDK: PIN C6 (VREFB8N0) is assigned to RAM_CS#
I have quite a few questions for the BeMicro SDK, but one at a time.
The support material is pretty lacking and doesn't even include a pin assignment. I made one based on the schematics, but when I try to instantiate the DDR memory controller, it fails to place with the message:
"Error: Cannot place I/O pin mem_dq[8] in pin location E8 -- I/O standard assigned to pin requires VREF value and VREF pin corresponding to pin location not available
Error: Cannot place I/O pin mem_dq[9] in pin location E7 -- I/O standard assigned to pin requires VREF value and VREF pin corresponding to pin location not available
Error: Cannot place I/O pin mem_dq[10] in pin location E6 -- I/O standard assigned to pin requires VREF value and VREF pin corresponding to pin location not available
Error: Cannot place I/O pin mem_dq[11] in pin location A7 -- I/O standard assigned to pin requires VREF value and VREF pin corresponding to pin location not available
Error: Cannot place I/O pin mem_dq[12] in pin location B7 -- I/O standard assigned to pin requires VREF value and VREF pin corresponding to pin location not available
Error: Cannot place I/O pin mem_dq[13] in pin location B6 -- I/O standard assigned to pin requires VREF value and VREF pin corresponding to pin location not available
Error: Cannot place I/O pin mem_dq[14] in pin location B5 -- I/O standard assigned to pin requires VREF value and VREF pin corresponding to pin location not available
Error: Cannot place I/O pin mem_dq[15] in pin location A5 -- I/O standard assigned to pin requires VREF value and VREF pin corresponding to pin location not available
Looking at the schematics, I do see that the lower half of mem_dq lives in Bank 7 which does indeed have its VREF hooked up to 1.8 V, however Bank 8 has its VREF assigned to chip select!
Is this a bug? Any suggestions to how to workaround it (other than wasting half the SDRAM and only use the lower-order byte)?
Tommy
    davidsmoot,
    Could you please post the settings that you used in the sopc builder for the Microtronix SDRAM controller? I'm looking for Bank Address bits, Row Address bits, Column Address bits, Total Number of Discrete Memory Devices, etc. that are in the Memory Tab of the parameters. That would be appreciated.
    I have the BeMicro SDK, and downloaded the Microtronix memory controller. I built my system using SOPC, and instantiated the system in my high-level entity (VHDL). When I compile I get the following errors, and I am not sure what is the problem.
    Any help is highly appreciated!
    Error: The DDIO_OUT WYSIWYG primitive "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_ddr_master_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:0:ciii_dq|ddio_bidir_86k:auto_generated|ddio_outa[0]" feeding the node "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_ddr_master_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:0:ciii_dq|ddio_bidir_86k:auto_generated|input_cell_h[0]" has multiple fan-outs
    Error: The DDIO_OUT WYSIWYG primitive "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_ddr_master_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:1:ciii_dq|ddio_bidir_86k:auto_generated|ddio_outa[0]" feeding the node "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_ddr_master_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:1:ciii_dq|ddio_bidir_86k:auto_generated|input_cell_h[0]" has multiple fan-outs
    Error: The DDIO_OUT WYSIWYG primitive "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_ddr_master_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:2:ciii_dq|ddio_bidir_86k:auto_generated|ddio_outa[0]" feeding the node "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_ddr_master_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:2:ciii_dq|ddio_bidir_86k:auto_generated|input_cell_h[0]" has multiple fan-outs
    Error: The DDIO_OUT WYSIWYG primitive "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_ddr_master_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:3:ciii_dq|ddio_bidir_86k:auto_generated|ddio_outa[0]" feeding the node "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_ddr_master_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:3:ciii_dq|ddio_bidir_86k:auto_generated|input_cell_h[0]" has multiple fan-outs
    Error: The DDIO_OUT WYSIWYG primitive "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_ddr_master_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:4:ciii_dq|ddio_bidir_86k:auto_generated|ddio_outa[0]" feeding the node "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_ddr_master_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:4:ciii_dq|ddio_bidir_86k:auto_generated|input_cell_h[0]" has multiple fan-outs
    Error: The DDIO_OUT WYSIWYG primitive "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_ddr_master_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:5:ciii_dq|ddio_bidir_86k:auto_generated|ddio_outa[0]" feeding the node "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_ddr_master_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:5:ciii_dq|ddio_bidir_86k:auto_generated|input_cell_h[0]" has multiple fan-outs
    Error: The DDIO_OUT WYSIWYG primitive "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_ddr_master_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:6:ciii_dq|ddio_bidir_86k:auto_generated|ddio_outa[0]" feeding the node "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_ddr_master_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:6:ciii_dq|ddio_bidir_86k:auto_generated|input_cell_h[0]" has multiple fan-outs
    Error: The DDIO_OUT WYSIWYG primitive "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_ddr_master_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:7:ciii_dq|ddio_bidir_86k:auto_generated|ddio_outa[0]" feeding the node "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_ddr_master_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:7:ciii_dq|ddio_bidir_86k:auto_generated|input_cell_h[0]" has multiple fan-outs
    Error: The DDIO_OUT WYSIWYG primitive "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_gen_ddr_slave_dqs:1:gen_ddr_slave_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:0:ciii_dq|ddio_bidir_86k:auto_generated|ddio_outa[0]" feeding the node "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_gen_ddr_slave_dqs:1:gen_ddr_slave_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:0:ciii_dq|ddio_bidir_86k:auto_generated|input_cell_h[0]" has multiple fan-outs
    Error: The DDIO_OUT WYSIWYG primitive "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_gen_ddr_slave_dqs:1:gen_ddr_slave_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:1:ciii_dq|ddio_bidir_86k:auto_generated|ddio_outa[0]" feeding the node "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_gen_ddr_slave_dqs:1:gen_ddr_slave_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:1:ciii_dq|ddio_bidir_86k:auto_generated|input_cell_h[0]" has multiple fan-outs
    Error: The DDIO_OUT WYSIWYG primitive "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_gen_ddr_slave_dqs:1:gen_ddr_slave_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:2:ciii_dq|ddio_bidir_86k:auto_generated|ddio_outa[0]" feeding the node "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_gen_ddr_slave_dqs:1:gen_ddr_slave_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:2:ciii_dq|ddio_bidir_86k:auto_generated|input_cell_h[0]" has multiple fan-outs
    Error: The DDIO_OUT WYSIWYG primitive "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_gen_ddr_slave_dqs:1:gen_ddr_slave_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:3:ciii_dq|ddio_bidir_86k:auto_generated|ddio_outa[0]" feeding the node "bemicro_sys:bemicro_sys_inst|mtx_avalon_sdram_0:the_mtx_avalon_sdram_0|mtx_sdram_controller:sdram|mtx_sdram_ddr_bidir:\gen_ddr_datapath:gen_cyclone_datapath:gen_ddr_dqs_groups:0:gen_gen_ddr_slave_dqs:1:gen_ddr_slave_dqs|altddio_bidir:\gen_ciii_dq:gen_dq_loop:3:ciii_dq|ddio_bidir_86k:auto_generated|input_cell_h[0]" has multiple fan-outs
    Do you have a working project setup with the evaluation IP that you are willing to share?
    Has anyone found a solution for the originally posted problem: Altera's DDR controller yielding
    "I/O standard assigned to pin requires VREF value and VREF pin corresponding to pin location not available"
    I'm afraid there is no solution besides either using Microtronix's IP or writing your own.
    I haven't tried the former and just as I started the latter, my BeMicro SDK appears to
    have died, so that solved my problem :rolleyes:
    Hopefully someone will make a new device like it or the micro DE0 when Cyclone V finally
    comes out next year.
    Tommy
    Thanks for the reply Tommy.
    What bugs me about this is it seems the Altera design is imposing an unnecessarily strict IO Standard. The Microtronix IP works fine with the pins defined as standard 1.8V... so why does Altera insist they be SSTL?
    If there was some way to disable the check in the Altera IP, could it perhaps be made to work? I wouldn't even know where to look for this, mind you...
    Got some more info to add... check this out:
    http://www.altera.com/support/kdb/solutions/rd01042008_479.html?gsa_pos=1&wt.oss_r=1&wt.oss=mobile
    "The Cyclone® IV devices use non-DQS read capture whereby the DQS signal is ignored." Which they say doesn't work for Mobile DDR (more details at the page above).
    So how does the Microtronix IP work if the Cyclone IV doesn't have the requisite read captuer? By "using the PCIe delay feature and logic elements".
    Sounds like they figured out a workaround which uses the PCIe hardware of the Cyclone. Presumably Altera's DDR controller does not contain this workaround.
    SO, assuming one wanted to do this themselves... anyone know how to go about "using the PCIe delay feature and logic elements" of the Cyclone IV?
    Cheers,
    Don
