15 years agoBeMicro SDK: PIN C6 (VREFB8N0) is assigned to RAM_CS#
I have quite a few questions for the BeMicro SDK, but one at a time. The support material is pretty lacking and doesn't even include a pin assignment. I made one based on the schematics, but wh...
14 years agoThanks for the reply Tommy.
What bugs me about this is it seems the Altera design is imposing an unnecessarily strict IO Standard. The Microtronix IP works fine with the pins defined as standard 1.8V... so why does Altera insist they be SSTL? If there was some way to disable the check in the Altera IP, could it perhaps be made to work? I wouldn't even know where to look for this, mind you...
