ATX pll Reconfiguration not changing clock frequency
- 5 years ago
Thanks for your update and sharing of the Modelsim simulation screenshot. For your information, as per the S10 L/H-Tile user guide, prior to reconfiguring ATX PLL, you would need to set the pre_reconfig bit -> return bus to PreSICE -> wait for pll_cal_busy to go low -> request bus from PreSICE -> initiate the embedded streamer.
Also, I notice that in your write data to the embedded streamer, the 540[7] bit is not written as 1. You would need to write this bit to 1 to initiate the streaming. You may refer to the section "A.1.4. Embedded Streamer" in the user guide for further details.
You may also refer to the following sections in the user guide
1. "Embedded Reconfiguration Streamer"
2. "Native PHY IP or PLL IP Core Guided Reconfiguration Flow"
As I understand it, you have some inquiries related to the ATX PLL dynamic reconfiguration. Please allow me some time to look into it and get back to you. Please ping me if you do not hear back from me by end of the week. Thank you.
- Rk_Athram5 years ago
Hi @CheePin_C_Intel,
Thank you for your quick response
Please see the attached snapshot/ block for brief understanding of project.
Rajesh - Rk_Athram5 years ago
Please see the attached snapshot/ block diagram of project for brief understanding.
Rajesh
