WKUAN's avatar
WKUAN
5 years ago
ARRIA 10: The impedance between VCC and GND is only 2Ω
Folks, I just finished the soldering of Arria10 10AX115NF45 chip. After the soldering , I measured the impedance between VCC and GND and found that it was only 2 ohm, between VCCA_PLL and GND was only 20 ohm. Is this normal?At present, the PCB has not been powered on.
  • EngWei_O_Intel's avatar
    EngWei_O_Intel
    Hi Wu Kuang
    We do not have specification for this. May I know your concern of this?
    Eng Wei
    • WKUAN's avatar
      WKUAN
      Dear Eng Wei
      Thanks for your reply, I want to know if the impedance between VCC(0.9V) and GND is too low (2ohm)? Is it damaged or still nomal? I have to make sure the chip is ok before power the board up.
      Thanks and best regards,
      KUANG Wu
        EngWei_O_Intel
        Hi Kuang Wu
        We don't have data on this so I am not able to confirm on this. What is the expected measurement? Are you trying to identify whether they are short circuit?
        Eng Wei
  • WKUAN's avatar
    WKUAN
    Hello all, I have powered the board on, it is ok, the 2Ω impedance between VCC and GND is nomal.
      EngWei_O_Intel
      I’m glad that you have your issue resolved, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
      Eng Wei
      • WKUAN's avatar
        WKUAN
        thank you, Eng Wei
