WKUAN
5 years agoARRIA 10: The impedance between VCC and GND is only 2Ω
Folks, I just finished the soldering of Arria10 10AX115NF45 chip. After the soldering , I measured the impedance between VCC and GND and found that it was only 2 ohm, between VCCA_PLL and GND was onl...
WKUAN
5 years agoDear Eng Wei
Thanks for your reply, I want to know if the impedance between VCC(0.9V) and GND is too low (2ohm)? Is it damaged or still nomal? I have to make sure the chip is ok before power the board up.
Thanks and best regards,
KUANG Wu
EngWei_O_Intel
5 years agoHi Kuang Wu
We don't have data on this so I am not able to confirm on this. What is the expected measurement? Are you trying to identify whether they are short circuit?
Eng Wei
- WKUAN5 years ago
Hi Eng Wei,
Yes, I am trying to identify whether they are short circuit
KUANG Wu
