Arria 10 Dev Kit - DDR4 calibration failed
Hi everyone,
I can't get the DDR4 module that comes with the Arria 10 Dev Kit to work. When I configure the DDR4 design using BTS, I get "DDR4 calibration failed, test won't work" error message. All other examples working fine (Flash/GPIO, FMC loopback and DDR3). Is there any configuration / setting that I am not ware of? Thanks5 Replies
If DDR3 works, DDR4 should work. Have you swapped out the memory in the Hi/Lo port?
--- Quote Start --- If DDR3 works, DDR4 should work. Have you swapped out the memory in the Hi/Lo port? --- Quote End --- Yes, I did swap out the memory module. - Altera_Forum
BTS should work out of the box. If it's not, I'd contact Intel for a replacement.
Check if the following setting is ON:
set_global_assignment -name RELEASE_CLEARS_BEFORE_TRI_STATES ON If it is as shown above, then you need to change it to OFF and then try again set_global_assignment -name RELEASE_CLEARS_BEFORE_TRI_STATES OFF- Suresh
DDR4 calibration failed in A10 dev kit out of the box. Following is the calibration report from External Memory Interface Toolkit
; Calibration ; Fail ;
; Initial failing group ; 2 ;
; Initial failing calibration stage ; Write Per-bit Deskew ;+---------------------------------------+
; Calibration Status Per Group ;
; Group ; Status ; Error Stage ;
; 0 ; Pass ; N/A ;
; 1 ; Pass ; N/A ;
; 2 ; Fail ; Write Per-bit Deskew ;
; 3 ; Fail ; Write Per-bit Deskew ;
; 4 ; Fail ; Write Per-bit Deskew ;
; 5 ; Fail ; Write Per-bit Deskew ;
; 6 ; Fail ; Write Per-bit Deskew ;
; 7 ; Fail ; Write Per-bit Deskew ;
; 8 ; Fail ; Write Per-bit Deskew ;
+-------+--------+----------------------+Calibration passed for group 0 and 1 but failed for rest of the groups even after assigning RELEASE_CLEARS_BEFORE_TRI_STATES OFF
