8 years agoArria 10 Dev Kit - DDR4 calibration failed
Hi everyone, I can't get the DDR4 module that comes with the Arria 10 Dev Kit to work. When I configure the DDR4 design using BTS, I get "DDR4 calibration failed, test won't work" error message...
8 years ago --- Quote Start --- If DDR3 works, DDR4 should work. Have you swapped out the memory in the Hi/Lo port? --- Quote End --- Yes, I did swap out the memory module.
