Arria 10 : HPS to FPGA Bridge Enable
I am using Arria 10 SoC on custom board and want to design a program for HPS and FPGA communication. In the manuals I read that we need to enable the bridges for HPS and FPGA communication .
I have generated dtb file using sopc2dts tool and used the board info xml files.
The linux dts file includes the bridges address but no bridge enable command is included:
sopc0: sopc@0 {
device_type = "soc";
ranges;
#address-cells = <1>;
#size-cells = <1>;
compatible = "ALTR,avalon", "simple-bus";
bus-frequency = <0>;
a10_hps_bridges: bridge@0xc0000000 {
compatible = "altr,bridge-17.1", "simple-bus";
reg = <0xc0000000 0x20000000>,
<0xff200000 0x00200000>;
reg-names = "axi_h2f", "axi_h2f_lw";
clocks = <&clk_0 &clk_0 &clk_0 &clk_0>;
clock-names = "h2f_axi_clock", "h2f_lw_axi_clock", "f2sdram0_clock", "f2sdram2_clock";
#address-cells = <2>;
#size-cells = <1>;
ranges = <0x00000000 0x00040000 0xc0040000 0x00000004>,
<0x00000000 0x00040004 0xc0040004 0x00000004>,
<0x00000000 0x00000000 0xc0000000 0x00040000>,
<0x00000001 0x00000000 0xff200000 0x00000020>,
<0x00000001 0x00000020 0xff200020 0x00000020>,
<0x00000001 0x00000200 0xff200200 0x00000100>,
<0x00000001 0x00000330 0xff200330 0x00000008>,
<0x00000001 0x00000320 0xff200320 0x00000010>,
<0x00000001 0x00000310 0xff200310 0x00000010>,
<0x00000001 0x00000300 0xff200300 0x00000010>;
On booting , no message of bridge initialisation is printed on console output.
The commnad : dmesg | grep fpga prints following output-
[ 1.117432] socfpga-dwmac ff800000.ethernet: PTP uses main clock
[ 1.123676] socfpga-dwmac ff800000.ethernet: User ID: 0x10, Synopsys ID: 0x37
[ 1.130827] socfpga-dwmac ff800000.ethernet: DWMAC1000
[ 1.136046] socfpga-dwmac ff800000.ethernet: DMA HW capability register suppd
[ 1.143497] socfpga-dwmac ff800000.ethernet: RX Checksum Offload Engine suppd
[ 1.150957] socfpga-dwmac ff800000.ethernet: COE Type 2
[ 1.156170] socfpga-dwmac ff800000.ethernet: TX Checksum insertion supported
[ 1.163187] socfpga-dwmac ff800000.ethernet: Enhanced/Alternate descriptors
[ 1.170127] socfpga-dwmac ff800000.ethernet: Enabled extended descriptors
[ 1.176895] socfpga-dwmac ff800000.ethernet: Ring mode enabled
[ 1.182703] socfpga-dwmac ff800000.ethernet: Enable RX Mitigation via HW Watr
[ 1.371423] fpga_manager fpga0: SoCFPGA Arria10 FPGA Manager registered
[ 2.907781] systemd[1]: Configuration file /lib/systemd/system/fpga-overlay..
[ 6.566431] socfpga-dwmac ff800000.ethernet eth0: No Safety Features supportd
[ 6.574028] socfpga-dwmac ff800000.ethernet eth0: IEEE 1588-2008 Advanced Tid
[ 6.583696] socfpga-dwmac ff800000.ethernet eth0: registered PTP clock
I need to enable the bridges also read and write some data from HPS to FPGA . I also tried to read and write over memory(addresses of bridges) using mw and md commands at uboot level . But there is data abort error and the commands are resetting the CPU .
Could anyone please help with the same.
Thanks ,
Priya
- EBERLAZARE_I_Intel
Can I get the Quartus and SoC EDS version that you are using?
Were you able to enable this using the Arria 10 SoC dev-kit?
I apologize for the delay in response.
- PJais1
Hello @EberL_Intel ,
I am using Quartus Prime Pro v17.1 and SoC EDS v17.1 . No, i am not using arria 10 development kit ,all the testing is done on custom board.
I did some changes in the dts file itself, by taking reference from some previous forum answers.
Now the bridges are displayed using dmesg | grep command , but a different error is encountered.
root@arria10:~# dmesg | grep fpga
[ 1.077679] socfpga-dwmac ff800000.ethernet: PTP uses main clock
[ 1.083888] socfpga-dwmac ff800000.ethernet: User ID: 0x10, Synopsys ID: 0x37
[ 1.091023] socfpga-dwmac ff800000.ethernet: DWMAC1000
[ 1.096238] socfpga-dwmac ff800000.ethernet: DMA HW capability register supported
[ 1.103688] socfpga-dwmac ff800000.ethernet: RX Checksum Offload Engine supported
[ 1.111147] socfpga-dwmac ff800000.ethernet: COE Type 2
[ 1.116356] socfpga-dwmac ff800000.ethernet: TX Checksum insertion supported
[ 1.123373] socfpga-dwmac ff800000.ethernet: Enhanced/Alternate descriptors
[ 1.130318] socfpga-dwmac ff800000.ethernet: Enabled extended descriptors
[ 1.137084] socfpga-dwmac ff800000.ethernet: Ring mode enabled
[ 1.142893] socfpga-dwmac ff800000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 1.331499] fpga_manager fpga0: SoCFPGA Arria10 FPGA Manager registered
[ 1.338379] altera_hps2fpga_bridge c0000000.fpgabridge: regmap for altr,l3regs lookup failed
[ 1.346926] altera_hps2fpga_bridge ff200000.fpgabridge: regmap for altr,l3regs lookup failed
[ 2.623801] systemd[1]: Configuration file /lib/systemd/system/fpga-overlay.service is marked executable. Please remove executable permissio.
[ 8.191159] socfpga-dwmac ff800000.ethernet eth0: No Safety Features support found
[ 8.198759] socfpga-dwmac ff800000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[ 8.207705] socfpga-dwmac ff800000.ethernet eth0: registered PTP clock
Can you help with the above error.
Priya
Hi Priya,
I am still working on this issue, as this was tested for a custom board, there are a lot of factors that might be affecting.
I will check with our internal team and try to find if there are any similar cases.
Regards.
