Arria 10 : HPS to FPGA Bridge Enable
Can I get the Quartus and SoC EDS version that you are using?
Were you able to enable this using the Arria 10 SoC dev-kit?
I apologize for the delay in response.
- PJais16 years ago
Hello @EberL_Intel ,
I am using Quartus Prime Pro v17.1 and SoC EDS v17.1 . No, i am not using arria 10 development kit ,all the testing is done on custom board.
I did some changes in the dts file itself, by taking reference from some previous forum answers.
Now the bridges are displayed using dmesg | grep command , but a different error is encountered.
root@arria10:~# dmesg | grep fpga
[ 1.077679] socfpga-dwmac ff800000.ethernet: PTP uses main clock
[ 1.083888] socfpga-dwmac ff800000.ethernet: User ID: 0x10, Synopsys ID: 0x37
[ 1.091023] socfpga-dwmac ff800000.ethernet: DWMAC1000
[ 1.096238] socfpga-dwmac ff800000.ethernet: DMA HW capability register supported
[ 1.103688] socfpga-dwmac ff800000.ethernet: RX Checksum Offload Engine supported
[ 1.111147] socfpga-dwmac ff800000.ethernet: COE Type 2
[ 1.116356] socfpga-dwmac ff800000.ethernet: TX Checksum insertion supported
[ 1.123373] socfpga-dwmac ff800000.ethernet: Enhanced/Alternate descriptors
[ 1.130318] socfpga-dwmac ff800000.ethernet: Enabled extended descriptors
[ 1.137084] socfpga-dwmac ff800000.ethernet: Ring mode enabled
[ 1.142893] socfpga-dwmac ff800000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 1.331499] fpga_manager fpga0: SoCFPGA Arria10 FPGA Manager registered
[ 1.338379] altera_hps2fpga_bridge c0000000.fpgabridge: regmap for altr,l3regs lookup failed
[ 1.346926] altera_hps2fpga_bridge ff200000.fpgabridge: regmap for altr,l3regs lookup failed
[ 2.623801] systemd[1]: Configuration file /lib/systemd/system/fpga-overlay.service is marked executable. Please remove executable permissio.
[ 8.191159] socfpga-dwmac ff800000.ethernet eth0: No Safety Features support found
[ 8.198759] socfpga-dwmac ff800000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[ 8.207705] socfpga-dwmac ff800000.ethernet eth0: registered PTP clock
Can you help with the above error.
Priya
- EBERLAZARE_I_Intel6 years ago
Hi Priya,
I am still working on this issue, as this was tested for a custom board, there are a lot of factors that might be affecting.
I will check with our internal team and try to find if there are any similar cases.
Regards.
