PJais1's avatar
PJais1
7 years ago
Arria 10 : data abort after DDR calibration
I am designing Linux OS for our custom board based on Arria 10 SoC.I have build uboot and peripheral rbf image and uploaded them in SD card.In our custom board we have used DDR3 memory at HPS side.
While booting, the console is showing a data abort and prefetch error after DDR calibration:
U-Boot 2014.10 (Sep 19 2019 - 11:13:27)
CPU : Altera SOCFPGA Arria 10 Platform
BOARD : Altera SOCFPGA Arria 10 Dev Kit
I2C: ready
DRAM: WARNING: Caches not enabled
FPGA: writing ghrd_10as066n2.periph.rbf..
FPGA: Early Release Succeeded.
SF: Detected N25Q1024A with page size 256 Bytes, erase size 4 KiB, total 128 MiB
DDRCAL: Success
INFO : Skip relocation as SDRAM is non secure memory
Reserving 2048 Bytes for IRQ stack at: ffe3a6e8
DRAM : 2 GiB
Wdata abort
prefetch aààort
Could anyone please suggest how to remove this error?
Priya
  • Hi,
    Just to check, when using the DDR4 memory, were you able to boot the Arria 10 successfully?
    Are you using the design from our GHRD?
    Regards.
    • PJais1's avatar
      PJais1
      I haven't designed using DDR4 as in our custom design DDR3 is connected at HPS side. Also , I am using the design from example design in SOC EDS embedded folder .
      • PJais1's avatar
        PJais1
        In our design we did not had ECC enabled . You might check the design parameters in the quartus tool for the DDR used.
