aocl install failed
- 5 years ago
Hi @clonedchocobo,
Thank you for your patients and details screenshot provided, after some investigation, based on the error I would assume that it is failed to installed the runtime driver for OpenCL.
Suspecting that there might be a missed in setting the environment variable for your machine.Perhaps you can refer to the following steps here, which will guide you through.
Also can you please run the 'aocl diagnose' command just to check on the installation and inilization of the runtime driver as well.
Warm regards
BB
Hi @clonedchocobo,
Thank you for posting in Intel community forum and hope this message find you well.
Is there a more details error generate on the output tab or something similar? It would help us understand the situation better if you are able to share that.
Also what are the Ubuntu and kernel version you had installed?
Note: in the user guide, there are also a section where 'The aocl install command fails due to a problem with PCIe drivers', just a reminder to review that to see if it is related.
Warm regards.
- clonedchocobo5 years ago
I do not have Ubuntu installed. I'm using Windows 10 version 1909. There is no mention anywhere that we have to work in non-Windows environment.
I've attached screenshots of all the steps that I've performed until I encountered 'aocl install failed'.
Best regards
- BoonBengT_Altera5 years ago
Moderator
Hi @clonedchocobo,
Warm regards
BB- clonedchocobo5 years ago
Thanks @BoonBengT_Altera . Disabling signed driver verification was the necessary missing step.
