mahi_72931
3 years agoAltera USB Blaster (usb-0)
Hi all, i have a device which used fpga cyclone v 5CEBA4U15C7, iam using quartus prime lite 19.1, my goal is to access this fpga device through a jtag connection (connections are done) and flash sof...
NurAiman_M_Intel
3 years agoHi,
- Is this the first time you are programming the board by using the USB Blaster?
- If not, has it ever work before?
- Please try to uninstall and reinstall the USB Blaster driver. Please ensure to install the driver correctly.
- Can you also try to use other USB blaster? Or if you have USB Blaster II, you can also use that.
- Please try to program by using another working board with current FPGA and USB blaster.
Aiman
