santosh2uu2
1 year agoALTERA DE1SoC HPS booting using SD card (PuTTY not responding)
I am working on the DE1-SoC Cyclone V board and attempting to set up the ARM/HPS booting process. Quartus HPS Project in windows: I am using Quartus prime lite 24.1 on a Windows machine. I have con...
Jeet14
1 year agoHi,
I see you have one open IPS case opened with your local FAE.
I have gone through the design which you have shared to FAE.
I don't see that you have enabled any UART port from the HPS IP.
Also, I suspect that you have not configured proper SD CARD pins like 4 data pin and DDR freq and other parameters.
For better understanding, I suggest you to go through the below GHRD
https://www.emb4fun.de/fpga/de1socghrd/index.html#download
Tiwari
