mjuneja2007
1 year agoAgilex board POF file programming - causing lspci enumeration problem
Hello I have generated a SOF file using CXL IP example design and then converted the same into POF using below settings and these steps 3.1.7.5.1. Converting .sof to .pof File Configuration mode: ...
Farabi_Altera
1 year agoHello,
I have escalated this issue to PCIe/CXL subject matter expert. We will continue to support you on case 06613600.
I am closing this case.
regards,
Farabi
