mjuneja2007
1 year agoAgilex board POF file programming - causing lspci enumeration problem
Hello I have generated a SOF file using CXL IP example design and then converted the same into POF using below settings and these steps 3.1.7.5.1. Converting .sof to .pof File Configuration mode: ...
mjuneja2007
1 year agoHi Farabi
By updating Linear Format N (in Power Management & VID) from -13 to -12, the issue of "SOF Configuration not completing" resolves and even CONF_DONE signal turns high (as confirmed in Configuration Debugger).
But when I convert this SOF into POF and put it in Agilex board flash memory. Then after rebooting, host doesn't turns up :(.
regards
Madhur
