Agilex 7: Not able to access the FPGA fabric from HPS through light weight AXI bus
Hi Teh,
Thanks for the reply.
I have done the below:
i. Modified the device tree in Uboot: socfpga_agilex7.dtsi.
I made the below modification to include the light weight AXI and normal AXI bus access:
In order to make the change, I took reference from the existing device tree implementation in Uboot.
fpga_bridge_lwsoc2fpga: lwsoc2fpgabridge@f9000000 {
#address-cells = <1>;
#size-cells = <0>;
compatible = "gdsys,ihs_axi";
reg = <0xf9000000 0x00200000>;
reg-names = "axi_h2f_lw";
clock-names = "h2f_lw_axi_clock";
resets = <&rst LWHPS2FPGA_RESET>;
little-endian;
init-val = <1>;
u-boot,dm-pre-reloc;
fpga_bridge_soc2fpga: soc2fpgabridge@80000000 {
#size-cells = <0>;
compatible = "gdsys,ihs_axi", "simple-bus";
reg = <0x80000000 0x40000000>;
reg-names = "axi_h2f";
clock-names = "h2f_axi_clock";
resets = <&rst SOC2FPGA_RESET>;
little-endian;
init-val = <1>; //H2F_AXI_MASTER>;
I am able to enable the bridge using the below command:
bridge enable 0x2 as well as bridge enable 0x3
I created a new DTSI file named my_agilex_fpga.dtsi and include it in the socfpga_agilex7_socdk.dts as below:
#include "my_agilex_fpga.dtsi"
I followed the below page to create the "my_agilex_fpga.dtsi" file:
https://www.rocketboards.org/foswiki/Documentation/HOWTOCreateADevicetreeForAgilexSoC#:~:text=dtsi%20file%20contains%20the%20definition,all%20the%20HPS%20IO%20peripherals.
Kindly let me know whether I am doing things correctly or not.
SpectralSensors
Hi Teh,
It seems my issue got resolved.
If I face any other issue then I will create another ticket.
SpectralSensors
