Agilex 7: Not able to access the FPGA fabric from HPS through light weight AXI bus
Hi Sanjat
Any update on this case?
If you are not editing it from the GSRD.
Please take note to add the declaration of the bridge in the device tree.
Jingyang, Teh
- spectralsensors2 years ago
Hi Teh,
Thanks for the reply.
I have done the below:i. Modified the device tree in Uboot: socfpga_agilex7.dtsi.
I made the below modification to include the light weight AXI and normal AXI bus access:
In order to make the change, I took reference from the existing device tree implementation in Uboot.
fpga_bridge_lwsoc2fpga: lwsoc2fpgabridge@f9000000 {
#address-cells = <1>;
#size-cells = <0>;
compatible = "gdsys,ihs_axi";
reg = <0xf9000000 0x00200000>;
reg-names = "axi_h2f_lw";
clock-names = "h2f_lw_axi_clock";
resets = <&rst LWHPS2FPGA_RESET>;
little-endian;
init-val = <1>;
u-boot,dm-pre-reloc;
fpga_bridge_soc2fpga: soc2fpgabridge@80000000 {
#size-cells = <0>;
compatible = "gdsys,ihs_axi", "simple-bus";
reg = <0x80000000 0x40000000>;
reg-names = "axi_h2f";
clock-names = "h2f_axi_clock";
resets = <&rst SOC2FPGA_RESET>;
little-endian;
init-val = <1>; //H2F_AXI_MASTER>;
I am able to enable the bridge using the below command:
bridge enable 0x2 as well as bridge enable 0x3
I created a new DTSI file named my_agilex_fpga.dtsi and include it in the socfpga_agilex7_socdk.dts as below:
#include "my_agilex_fpga.dtsi"
I followed the below page to create the "my_agilex_fpga.dtsi" file:
https://www.rocketboards.org/foswiki/Documentation/HOWTOCreateADevicetreeForAgilexSoC#:~:text=dtsi%20file%20contains%20the%20definition,all%20the%20HPS%20IO%20peripherals.Kindly let me know whether I am doing things correctly or not.
SpectralSensors
Hi Teh,
It seems my issue got resolved.
If I face any other issue then I will create another ticket.
SpectralSensors
