Agilex 7 DevKit - BTS GUI works but Transceiver Toolkit fails
Windows 11, Quartus 24.1 (also tried 24.3, 24.3.1, 25.1), DK-SI-AGI040EA
BTS GUI connects to DevKit without any issue. I can load a configuration file, I can see BERs and everything works properly.
I then close the BTS and open the transceiver toolkit and, load the image in \examples\board_test_system\image\PRD\, i.e. the same one that I loaded in the BTS. The image loads properly and I can see all the instances of the active transceivers.
However, when I click on one of the transceivers to create a collection, I get the following error:
Jun 21, 2025 9:20:20 PM Intel F-Tile Transceiver Toolkit: f_dphy_adme[0].f_dphy_adme_inst
SEVERE: An error occurred while running script "ftile_callback_pkg::init_callback
": Intel F-Tile Transceiver Toolkit: f_dphy_adme[0].f_dphy_adme_inst: can't read "avmm2_path": no such variable
while executing
"args_path_devtype_servicetype_xcvrtype_numlanes_step $avmm2_path $devtype $service_type $xcvr_type $num_lanes $step"
(procedure "pysv_driver::start" line 104)
invoked from within
(procedure "ftile_callback_pkg::init_callback" line 20)
invoked from within
What's the issue?
Attached is the transceiver toolkit log.
1 Reply
- Ash_R_Altera
I think, you have similar query in another similar case.
Agilex 7 DevKit | OSFP Board Test System | Transceiver Toolkit Error - Intel Community
Please follow up on that.
