50/60Hz Digital PLL
We want to implement a digital 50/60Hz PLL for synchronisation purpose.
We want to replace an old HEF4046B IC.
Is it possible to design a 50/60Hz with FPGA/CPLD (MAX10 family i.e)? do you have any reference design?
- Rahul_S_Intel1
Hi ,
You can use PLL for the generation
- Rahul_S_Intel1
Hi ,
Kindly let me know , if you need further assistance.
Rahul S
- hpola3
Hi Rahus,
In Max10 internal PLLs minimum frequency range is in MHz range.
I need a PLL for 50/60Hz application (grid frequency lock). Also PLLs has a filter which adjust its slew rate and speed.
Do you think is it possible with Max10 family? Do you have an IP of reference design for such application?
- Rahul_S_Intel1
Hi ,
May I know the below suggestion will work or not .
Implement a counter , where you know the input frequency and make the counter to your desired clock out put . I find my code may be it will be useful for you .
library IEEE;
use IEEE.NUMERIC_STD.all;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity scale_clock is
port (
clk_50Mhz : in std_logic;
rst : in std_logic;
clk_2Hz : out std_logic
end scale_clock;
architecture Behavioral of scale_clock is
signal prescaler : unsigned(23 downto 0);
signal clk_2Hz_i : std_logic;
begin
gen_clk : process (clk_50Mhz, rst)
begin -- process gen_clk
if rst = '1' then
clk_2Hz_i <= '0';
prescaler <= (others => '0');
elsif rising_edge(clk_50Mhz) then -- rising clock edge
if prescaler = X"BEBC20" then -- 12 500 000 in hex
clk_2Hz_i <= not clk_2Hz_i;
else
prescaler <= prescaler + "1";
end if;
end if;
end process gen_clk;
clk_2Hz <= clk_2Hz_i;
end Behavioral;
- Rahul_S_Intel1
Hi ,
Kindly let me know if you need further assistance
