10G/25G Ethernet vs 10G MAC + 10GBASE-R PHY
- 5 years ago
HI,
Pls see my comment below
1. For a new system is there any general recommendation on which IP to use, either the 25G Ethernet or a combination of LLE 10G MAC and 10GBASE-R PHY?
- Since you are just interested with 10G application then it make more sense for you to consider either
- LLE 10G MAC + 10GBASE-R PHY
- or LLE 10G MAC + 1G/2.5G/5G/10G Multi-rate Ethernet PHY
2. It doesn't seem like it, but is it possible configure the 25G Ethernet IP in such a way that it would start in, or only operate in, 10G mode ?
- Unlikely as this IP is meant for 25G application with additional option to downgrade to 10G. So, It will start with 25G
3. Is the main purpose of the 10G/25G rate switching (in the 25G Ethernet IP) to allow rate switching on the fly, or is this also intended to replace the 10G MAC + PHY and allow backwards compatibility with 10GbE systems ?
- The rate switching option allow on the fly speed change via the reconfiguration process change as shown in example design link
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-dex-s10-25gbe.pdf
- I won't say replacement but think of it like next generation Ethernet IP solution that able to support till 25G but at the same time still preserve backwards compatibility with 10GbE systems
dlim
Intel won't be able to guarantee any IP offer will last for how long as it's actually depend on market demand and supply dynamic.
Intel marketing team will evaluate the IP solution annually to decide whether to continue sustain it or EOL it. The judgement is purely base on business call.
I am sorry this Intel forum community is meant to address technical enquiry while business justification is out of my control.
Perhaps you can contact your local sales distributor to see if they can give you better answer from business support perspective
dlim
- kgigliotti5 years ago
@Deshi_Intel, thanks again for the response.
I figured this might be the case, as with most things from a business perspective, but it doesn't hurt to ask.
Either way, I really appreciate the additional feedback and input.
Cheers
