Joseph_Wilger's avatar
Joseph_Wilger
1 year ago
10AX027E3F29E2SG Pin AB19 voltage (IO-AB19 / LVDs2J)
Pin AB19 has a low voltage.
A good board has proper voltage waveform (1.8 Vdc high, and ≤ 0.3 Vdc low).
This is a waveform amplitude of 1.5 volts difference (1.8 Volt rail).
  • FvM's avatar
    FvM
    why are you starting a new thread instead of continuing the previous one? https://community.intel.com/t5/Programmable-Devices/Unexpected-Voltage-output-on-pin-AB19/m-p/1711288
    Anyway, now we know at least about used device. Still not clear how the pin is connected in your circuit? How much pull-down current is required by the external circuit to achieve expected 0V level? A schematic would be preferred for explanation. Is it an off-the-shelf development kit or your own design? Which I/O standard is configured for the pin?
    Frank
    • Joseph_Wilger's avatar
      Joseph_Wilger
      1. why are you starting a new thread ... I was unable to navigate my browser back to the original thread. There was also no eMail link I could use.
      2. Still not clear how the pin is connected in your circuit? How much pull-down current is required by the external circuit to achieve expected 0V level? See below.
      3. A schematic would be preferred for explanation. I am unable to share the schematic - without and NDA in place. Certainly not on an open forum like this.
      4. Is it an off-the-shelf development kit or your own design? Our own design.
      5. Which I/O standard is configured for the pin? I will check.
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    Any update on questions 2 and 5?
    For the schematic, you can share it privately with me via email. Let me know if you wish to send it.
    Aqid
      Joseph_Wilger
      Aqid:
      Thank you for the follow up.
      Do you happen to know if Boston Scientific has an NDA in place with Intel?
      Please send me your eMail address.
      Joe
    AqidAyman_Altera
    Hi Joe,
    For your information, I have no access on Intel's NDA and moving forward, we will be referring to Altera NDA.
    Let me know if you want to proceed. I will initiate an email to your account.
    Aqid
    AqidAyman_Altera
    Just so you know, I will not have access to this forum until October 14th. I will resume the support after the system is up again.
    If you want me to initiate the email, kindly confirm before tomorrow.
    AqidAyman_Altera
    As I do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
