Joseph_Wilger
1 year ago10AX027E3F29E2SG Pin AB19 voltage (IO-AB19 / LVDs2J)
Pin AB19 has a low voltage. A good board has proper voltage waveform (1.8 Vdc high, and ≤ 0.3 Vdc low). This is a waveform amplitude of 1.5 volts difference (1.8 Volt rail).
AqidAyman_Altera
1 year agoJust so you know, I will not have access to this forum until October 14th. I will resume the support after the system is up again.
If you want me to initiate the email, kindly confirm before tomorrow.
