RAlbe4's avatar
RAlbe4
7 years ago
Why I am getting this error (error while loading shared libraries: libaltera_a10_ref_mmd.so: cannot open shared object file: No such file or directory) while running OpenCL diagnostics?
Hello support.
I need to run the board diagnostics after installing my Arria 10 GX board.
However, I got this error
Is there anything missing?
this is an urgent issue please help..
  • Hello,
    it seems you have some issues with the PATH environment. I will help you until you get rid of this issue.
    Kindly ensure that you have set the PATH environment variable correctly. It can be something like this:
    export PATH=$PATH:$INTELFPGAOCLSDKROOT/bin:$QUARTUS_DIR/bin
    Please let me know if this could help you.
    Thank you.
  • FawazJ_Altera's avatar
    FawazJ_Altera
    Thank you.
  • RAlbe4's avatar
    RAlbe4
    Hello Fjumaah,
    Thank you very much for your support. Your answer helped me to fix the issue out.
    You saved my day ...
