RAlbe4
7 years agoWhy I am getting this error (error while loading shared libraries: libaltera_a10_ref_mmd.so: cannot open shared object file: No such file or directory) while running OpenCL diagnostics?
Hello support. I need to run the board diagnostics after installing my Arria 10 GX board. However, I got this error error while loading shared libraries: libaltera_a10_ref_mmd.so: cannot open s...
- 7 years ago
it seems you have some issues with the PATH environment. I will help you until you get rid of this issue.
Kindly ensure that you have set the PATH environment variable correctly. It can be something like this:
export PATH=$PATH:$INTELFPGAOCLSDKROOT/bin:$QUARTUS_DIR/bin
Please let me know if this could help you.
Thank you.
FawazJ_Altera
7 years agoHello,
Thank you.
