Björne
2 years agoWhy does aoc set ii to 6 when I use high clock frequencies?
I have a simple toy that I want to run at 1000 MHz kernel that doesn't do much: __attribute__((uses_global_work_offset(0))) __attribute__((max_global_work_dim(0))) __kernel void netsim( __global...
BoonBengT_Altera
Moderator
2 years agoHi @Björne,
Noted on the hardware involved and software version mention, to further clarify are you using the Intel OpenCL Compiler or Intel HLS compiler? I believe above are some custom code which you have written with the purpose to figure out the clock frequencies, it would be very helpful to provide us what are the steps to compile the example too.
Hope to hear from you soon.
Best Wishes
BB
