USB 3.0 Internal FPGA Transceiver
We are looking for an FPGA with inbuilt USB 3.0 transceiver. Earlier we were using external UB 3.0 Transceiver from TI. But this device is not available now and not recommended for future designs. So we are looking to re-design the product with inbuilt Transceiver inside FPGA. Any suggestion on suitable FPGA which supports USB 3.0 Transceiver is appreciated.
We have noticed the “eUSB3.0 Development Board” from FPGA. Is it possible to get more details regarding how USB 3.0 Transceiver is used.
- Kshitij_Intel
Hi Biju,
These are the devices Stratix V, Stratix 10, Cyclone V ST, Cyclone V SoC, Cyclone V GX, Cyclone V GT, Cyclone V E, Cyclone V, Cyclone 10 GX, Arria V SX, Arria V ST, Arria V SoC, Arria V GZ, Arria V GX, Arria V GT, Arria V, Arria 10 which supports eUSB 3.1 Gen 2 Device Controller.
You can also look into different options in below link.
https://www.slscorp.com/ip-cores/communication/usb-30-device/eusb3-0-device-controller-eusb30sf.html
Thank you
Kshitij Goel
- Bkuriako
Thank you K**bleep**ij Goel.
Whether Transceiver in Arria 10 device can be configured to meet USB 3.0 interface spec in terms of input and output voltage limits, de-emphasis setting and equalization setting as per USB 3.0 spec.
Biju
- Kshitij_Intel
A custom eUSB 3.1 Gen 2 is designed using the Intel® FPGA built-in transceiver by sls and tested with Arria 10 (up to Gen 2 10Gbps interface) which also supports the range from USB 3.1 to USB 2.0 with claiming it is as per USB 3.0/3.1 specs but how they have configured that info can be get with sls only. If they are claiming it is as per specs and tested on Arria 10 then the transceiver has to be configured as per specs.
Thank you
Kshitij Goel
- Bkuriako
Biju
- Kshitij_Intel
Hi Biju,
As We do not receive any response from you to the previous reply that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you.
Kshitij Goel
