USB 3.0 Internal FPGA Transceiver
Hi Biju,
These are the devices Stratix V, Stratix 10, Cyclone V ST, Cyclone V SoC, Cyclone V GX, Cyclone V GT, Cyclone V E, Cyclone V, Cyclone 10 GX, Arria V SX, Arria V ST, Arria V SoC, Arria V GZ, Arria V GX, Arria V GT, Arria V, Arria 10 which supports eUSB 3.1 Gen 2 Device Controller.
You can also look into different options in below link.
https://www.slscorp.com/ip-cores/communication/usb-30-device/eusb3-0-device-controller-eusb30sf.html
Thank you
Kshitij Goel
Thank you K**bleep**ij Goel.
Whether Transceiver in Arria 10 device can be configured to meet USB 3.0 interface spec in terms of input and output voltage limits, de-emphasis setting and equalization setting as per USB 3.0 spec.
Biju
- Kshitij_Intel4 years ago
A custom eUSB 3.1 Gen 2 is designed using the Intel® FPGA built-in transceiver by sls and tested with Arria 10 (up to Gen 2 10Gbps interface) which also supports the range from USB 3.1 to USB 2.0 with claiming it is as per USB 3.0/3.1 specs but how they have configured that info can be get with sls only. If they are claiming it is as per specs and tested on Arria 10 then the transceiver has to be configured as per specs.
Thank you
Kshitij Goel
