Typical way of loading runtime to Arm core (HPS)
I'm wondering what is the typical way to load runtime executable to FPGA once I build host and device by oneAPI.
I followed Agilex™ 7 FPGA I-Series Development Kit (2x R-Tile and 1x F-Tile) to boot up HPS on my Agilex™ 7 FPGA I-Series Development Kit (2x R-Tile and 1x F-Tile) . Now I can establish serial communication and run ./hello in the linux kernel. But I don't know how should I load executable files to FPGA devkit. Tutorials like Get Started with the Intel® oneAPI Base Toolkit for Linux* does not provide details on how to copy executable files to runtime system.
According to my experience of working with Xilinx ultrascale board, I can establish ethernet connection between host and device, and use 'scp' to copy executable files from host to device. Do I have similar options while using Agilex7 I-series devkit? There seems to be no ethernet or USB ports on my board.
Runlong
- Kevin_Xu_Intel
Hi Runlong,
Can you share more about your design/ project? Are you trying to offload accelerated computation? or generating RTL IP ? (Difference is explained here)
If you are trying to build a multiarchitecture executable, I believe we only support x86 machine as host (linux or windows) not the HPS core on our SoC FPGA. When you running the multiarchitecture executable (on the host) for the first time, it program the FPGA automatically.
I recommend following this tutorial to get started on running a simple oneAPI program on FPGA: https://github.com/oneapi-src/oneAPI-samples/tree/master/DirectProgramming/C%2B%2BSYCL_FPGA/Tutorials/GettingStarted/fpga_compile
-Kevin
- uniqueMR
Hi Kevin,
I just started with oneAPI tutorial for setting up the basic workflow, and the design that I am using is the vector-add sample (seems to be FPGA SYCL code). I want to try 'make fpga' step in Get Started with the Intel® oneAPI Base Toolkit for Linux* which is similar to the tutorial you shared. It suggests me to copy the executable file to the runtime system, and run the executable file.
By mentioning "we only support x86 machine as host (linux or windows) not the HPS core on our SoC FPGA", does it mean I need to run './vector-add-usm.fpga' on my x86 machine as host, and the FPGA will be programmed automatically?
And both of these two tutorials seem to hide the details of host-board connection. Is there a guidance on how I should physically connect my board with my x86 host machine? Now I seem to have 3 connections available: a micro-USB connection (recognized as AGI FPGA DevKit in Quartus), an Intel FPGA download cable II connection (recognized as USB-Blaster II in Quartus), and a UART serial communication connection. Are these enough to automatically program FPGA by running executable on the host?
Runlong
- Kevin_Xu_Intel
Hi Runlong,
- It suggests me to copy the executable file to the runtime system, and run the executable file.
The "runtime system" referring to the computer that the FPGA Card is connected to, either through PCI-E or USB. We mention copying here because it is common to use different machine to compile and run the executable.
- does it mean I need to run './vector-add-usm.fpga' on my x86 machine as host, and the FPGA will be programmed automatically?
Yes. Assuming you have the FPGA card connected and initialized, and proper driver and BSP/ASP installed. If not, I am linking some resources for how to do that:
- You need to install the oneapi base toolkit and the oneapi fpga support package. You also need to have Quartus installed.
- You need to install the Accelerator Support Package (ASP) for your specific board. You can usually get the ASP from your board vendor, or it can be generated by following this guide: https://ofs.github.io/ofs-2024.2-1/hw/common/user_guides/oneapi_asp/ug_oneapi_asp/
- You need to initialize your board: https://www.intel.com/content/www/us/en/docs/oneapi-fpga-add-on/developer-guide/2024-2/managing-an-fpga-board.html
Once the above is settled up, you can then run the executable such as "vector-add-buffers.fpga" same why you run any binary executable.
The step to generate BSP/ASP can be a bit involved, let me know if you need more help wit it.
-Kevin
- Jeet14
Please add below packages into your rootFS and add these into your local.conf file. Recompile the rootFS, with this you will be able to use the 'scp' command for transferring file from Host PC to board.
CORE_IMAGE_EXTRA_INSTALL list to get both scp and sftp clients and servers:
openssh
openssh-sftp
openssh-sftp-server
For building the RootFS, you can refer below link-
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderAgilex7#Building_Yocto_Rootfs
Tiwari
- Jeet14
Any update on the suggestion given in previous comment?
Tiwari
- uniqueMR
Hi Tiwari,
Thanks for following up. I find the path suggested by Kevin Xu might be more applied to my situation, so I want to try this first. Generating BSP/ASP myself seems to be too painful, so I'm trying to reach out and see if I can get those support packages that are specified for my board type. Btw, do you have suggestions on where I can possibly get well-crafted BSP/ASP for oneAPI development? Thanks.
Runlong Hu
- BoonBengT_Altera
Moderator
Hi @uniqueMR,
For oneAPI BSP you can find it based on the your device at the link below:
- https://www.intel.com/content/www/us/en/docs/oneapi/programming-guide/2023-1/fpga-bsps-and-boards.html (For PAC product)
- https://www.intel.com/content/www/us/en/developer/tools/oneapi/fpga.html (For non PAC product, please scroll to the 'Choose an FPGA Platform' section)
Hope that clarify
Best Wishes
BB
- Jeet14
Please let me know if you have any other query on this.
If no then, I will close this by today EOD.
Tiwari
- uniqueMR
Hi Jeet,
Thank you for following up. Kevin said he would help me getting BSP/ASP for my agilex7 i-series devkit. Now I'm still waiting for his feedback. Could you still keep this thread if there's no other way for me to catch up with any updates? Thanks a lot.
Best,
Runlong
- Jeet14
FYI, This thread will be open for community to support. You will receive update if anyone post to this thread.
I will close this case from my side as no query pending from my side.
Tiwari
