CShih23
2 years agoTrying oneAPI on Arria® 10 GX FPGA
I want to utilize OpenCL or oneAPI to facilitate communication between the host and FPGA. The board I'm using is the Arria® 10 GX FPGA Development Kit (10AX115S2F45I1SG). I have attempted this setup...
aikeu
2 years agoHi CShih23,
I think is ok to use the version for the reference dated back to 2023 as it is still a version suggested in the same document.
Aik Eu
- CShih232 years ago
Hi, Aik Eu
So, I signed up for the oneAPI cloud, and found the OS version is indeed 18.04.
However, the folder structure under /opt/intel/oneapiu222498@login-2:~$ ls /opt/intel/oneapi/ 2024.1 compiler dnnl intelpython logs openpgl rkutil advisor dal dpcpp-ct intel_s10sx_pac mkl openvkl setvars.sh ai_reference_models de10_agilex dpl ipp modulefiles-setup.sh ospray support.txt basekit debugger embree ippcp mpi ospray_studio tbb ccl dev-utilities hpckit ispc oidn renderkit tcm common diagnostics intel_a10gx_pac licensing oneApi-samples rkcommon vtuneis a bit different from what I have downloaded
aaaaa@aaaaaa:~$ ls /opt/intel/oneapi/ 2024.1 ccl dal diagnostics dpl ippcp mkl setvars.sh tcm advisor common debugger dnnl installer licensing modulefiles-setup.sh support.txt vtune basekit compiler dev-utilities dpcpp-ct ipp logs mpi tbbThere's no intel_a10gx_pac/bringup/opae there.
Is the BSP downloadable from the website?
