Strange behavior of Quartus Fitter and how to get more information
Hi @JavierHormigo,
Noted with thanks for the explanation and report.
As for request on getting more information on the fitter process, would suggest to look into the failed compilation logs you have provided. In the 'top.fit.rpt' files you would be able to get the details logs on how the fitter process goings.
As you look at the bottom of the result there is a mention failure on which region.
Hence would suggest going through the logs mention in the files.
Hope that clarify.
Best Wishes
BB
I have been going through the files you suggested but I still don't understand why a design that occupies significantly fewer resources fails to be fitted while the original implement with no errors. The report only said that there are not enough LABs in the region, but why?
Is it because the Quartus estimation is so wrong that instead of reducing the resources by 30% as it said, they actually grow? Is it because although the resources are less they are concentrated in the same region? If so, why? I have not changed anything to force the tool to put everything in the same region, why don't use a different region? How can I handle this situation?
Too many questions raised.
JAvier
