Ali8
2 years agoSlave Memory in OneAPI HLS Flow
In intel HLS compiler, we can implement a slave memory inside a component using hls_avalon_slave_memory_argument(N). The slave memory can also be implemented with M20K embedded RAM and can have the s...
- 2 years ago
Hi Ali,
Currently only the fpga_register attribute works on device globals (to force them into your datapath as registers).
Ali8
2 years agoThank you very much for your reply.
In case of device_global type, can I use the FPGA memory attributes such as [[intel::numbanks(N)]] , [[intel::private_copies(N)]], etc., to optimize memory accesses from the kernel.
