alperro
3 years agoSEGFAULT with vector-add example when running on FPGA Emulator
I have tried to compile and run the vector-add example but I get segmentation fault when running on FPGA emulator. It runs fine when running on CPU: Running on device: Intel(R) Xeon(R) CPU E5-2650 ...
BoonBengT_Altera
Moderator
3 years agoHi @alperro,
Good day, just following up on the previous clarification.
By any chances did you managed to look into the it?
Hope to hear from you soon.
Best Wishes
BB
alperro
3 years agoHello Boon Beng,
I was able to avoid the issue by using a different machine.
The broken configuration was using CentOS7 with Xeon E5-2650 v4.
The working configuration is using CentOS8 Stream with Xeon Gold 6326.
This is the link to the example in question
Best,
Alberto
