LennartVH
4 years agoSDC constraints with native module for OpenCL
I'm creating a native verilog module for use within an OpenCL kernel. I was wondering if it is possible to create SDC constraints for my native module. The openCL compiler does not accept .sdc fi...
LennartVH
4 years agoThank you, @BoonBengT_Altera
We've been able to solve the issue in a different way, where we transmit the constant over two wires to shift register receivers all across the FPGA. That saves us a lot of routing resources as well.
In any case thank you for the linked document, if the need comes up again we'll definitely consult it.
Kind regards,
Lennart
