Running oneAPI C++SYCL_FPGA GettingStarted Example on devcloud
- 2 years ago
Hi JSYOO,
The error "Caught a synchronous SYCL exception: NULL pointer .." is expected as you are targetting a specific device family. This flow (HLS SYCL Flow) produce RTL IP Core and are meant to be integrated into a system using Quartus/PD . *The 2 FPGA Development Flow can be referred here Intel oneAPI FPGA Development Flow.
As for As for "Error: The board package being used only supports report generation/emulation/runtime" it maybe due to the node used on DevCloud is not working properly. Can try other node and check if the same error will occur or not.
Aik Eu
Hi JSYOO,
Aik Eu
