JavierHormigo
3 years agoStrange behavior of Quartus Fitter and how to get more information
Hi, I'm designing an accelerator for DTW computation using oneAPI and Stratix 10 at the board BittWare 520N-MX Gen3x16. I have a kernel (it's actually several different kernels connected with pipes...
BoonBengT_Altera
Moderator
3 years agoHi @JavierHormigo,
Apologies for the hold up, you might be familiar with the report for quartus fitter available.
You would need to navigate to the report via System Resource Utilization Summary (Summary > System Resource Utilization Summary)
Report mention would have what quartus uses and oneAPI compiler estimation.
Just to add on to that, perhaps we can also navigate down to the kernels by the next table in the same tab.
Hopefully that will give an insight on which kernel are taking more resources, and from there some optimization would be required on the design to use less area.
Best Wishes
BB
JavierHormigo
3 years agoBut, the report you said only has values if the fitting is succesfull. it is empty in my case , when the implementation stops with errors.
thanks,
JAvier
