JavierHormigo
3 years agoStrange behavior of Quartus Fitter and how to get more information
Hi, I'm designing an accelerator for DTW computation using oneAPI and Stratix 10 at the board BittWare 520N-MX Gen3x16. I have a kernel (it's actually several different kernels connected with pipes...
BoonBengT_Altera
Moderator
3 years agoHi @JavierHormigo,
Apologies for the delayed in response, noted on the emulation as that rules our the code issues.
From your finding of fitting different kernel and are getting different resources, per understanding that might be due to the partition in the design.
The limit of kernel seems to be as mention which is 12 for the mention devices, as more than that it causes error on the resources. If more kernel are required to be fitted, a bigger devices would be required.
Hope that clarify.
Best Wishes
BB
JavierHormigo
3 years agoHi @BoonBengT_Altera ,
Sorry, but I don't understand your answer. How can I get more information on the fitter process to determine what is happening?
Thank you,
JAvier
