Stable argument doesn't work in simulation
- 2 years ago
Thanks for sharing the report, @DorianL .
It looks like the loop at line 137 was pipelined with II=1, but it was constrained to serial execution.
This means that this outer loop is effectively un-pipelined. This doesn't explain the gaps you are seeing in the simulation waveform though.
I also see that you are getting a memory system with lots of arbitration:After some experimenting, I discovered that the warning about the variable 'fenetre' is a bit of a red herring here. I would expect for a line buffer like you are describing to have a memory system with multiple banks, and each bank having a dedicated load/store unit (LSU). From the image above, we can see that the memory system is not efficiently selecting banks. I tried using the bank_bits attribute to constrain this, but it appears the compiler is ignoring this attribute now.
I was able to get the compiler to partition your 2d array by swapping the dimensions (transposing) so that the dimension to be split into banks (i.e. accessed simultaneously by different unrolled loop iterations) was in the least significant place. This appears to result in the desired memory system (don't forget to swap the accesses too!!)OLD:
// Ligne a retard [[intel::fpga_memory("BLOCK_RAM")]] // memory unsigned int line_buffer[8][NB_COLONNE_MAX];NEW:
// Ligne a retard [[intel::fpga_memory("BLOCK_RAM")]] // memory unsigned int line_buffer[NB_COLONNE_MAX][8];* Note that I changed the dimension from 5 to 8: the compiler complains if you try to create a memory system with a non-power-of-2 number of banks. Changing to 8 is ok because the compiler sees that the extra 3 banks aren't used and it optimizes them away.
The new memory system looks a lot better now:
The sim looks a lot better too:
I think i know how to solve these 2-cycle dips but I'm still waiting for the test to finish.
I suspect it's a side-effect of using a loop nest instead of using a while(1) loop to iterate across image pixels.
Hi DorianL,
Aik Eu
Hi @aikeu ,
I was waiting for an answer following my last post with my code and compilation commands as asked by @BoonBengT_Altera in a previous post. Could we wait an answer from him before closing the thread ? Thank you !
DorianL
- BoonBengT_Altera2 years ago
Moderator
Hi @DorianL,
Appreciate the hold, based on the explanation above on the first part when you are facing challenges in working with the loop's optimization, the Loop Analysis Report provides a good insight on the loop structure that you have written and would give some ideas on where the bottleneck is, more details on the report can be found in the following link below:
- https://www.intel.com/content/www/us/en/docs/oneapi-fpga-add-on/developer-guide/2024-1/loop-analysis.htmlOn the other hand, when you are trying the inner loop optimization and facing another issues when trying to implement the external function, you can use the 'std::default_random_engine' instead in c++.
More details of the implementation of inner loop optimization could be found in our git repo below:
- https://github.com/oneapi-src/oneAPI-samples/tree/master/DirectProgramming/C%2B%2BSYCL_FPGA/Tutorials/DesignPatterns/optimize_inner_loopHope that clarifies
BB- DorianL2 years ago
Thank you for the information but the issue is that in the kernel code I sent before the variable "taille_v" and "taille_h" are input of my IP and it increases the latency of the loop compared to when both variable are defined and not input anymore. Is this an issue that you have ever faced ? Thank you !
DorianL
