JohnT_Altera
1 year agoHi Ruben,
I think you might need to only provide new input of data and not changing the blob which will think that this is a new inference setting.
During the 1st run, you should have performed all the setting and during the second run onwards, you should just provide the input data.
RubenPadial
Contributor
11 months agoHello @JohnT_Intel,
Same behaviour.
I changed to create the blobs before the loop and only filling them in the loop:
// Create blobs only once before the loop using Blob_t = std::vector<std::map<std::string, Blob::Ptr>>; std::vector<std::pair<Blob_t, Blob_t>> ioBlobs = vectorMapWithIndex<std::pair<Blob_t, Blob_t>>( exeNetworks, [&](ExecutableNetwork* const& exeNetwork, uint32_t index) mutable { Blob_t inputBlobs; Blob_t outputBlobs; ConstInputsDataMap inputInfo = exeNetwork->GetInputsInfo(); ConstOutputsDataMap outputInfo = exeNetwork->GetOutputsInfo(); for (uint32_t batch = 0; batch < num_batches; batch++) { std::map<std::string, Blob::Ptr> outputBlobsMap; for (auto& item : outputInfo) { auto& precision = item.second->getTensorDesc().getPrecision(); if (precision != Precision::FP32) { THROW_IE_EXCEPTION << "Output blob creation only supports FP32 precision. Instead got: " + precision; } auto outputBlob = make_shared_blob<PrecisionTrait<Precision::FP32>::value_type>(item.second->getTensorDesc()); outputBlob->allocate(); outputBlobsMap[item.first] = (outputBlob); } std::map<std::string, Blob::Ptr> inputBlobsMap; for (auto& item : inputInfo) { Blob::Ptr inputBlob = nullptr; auto& precision = item.second->getTensorDesc().getPrecision(); if (precision == Precision::FP32) { inputBlob = make_shared_blob<PrecisionTrait<Precision::FP32>::value_type>(item.second->getTensorDesc()); } else if (precision == Precision::U8) { inputBlob = make_shared_blob<PrecisionTrait<Precision::U8>::value_type>(item.second->getTensorDesc()); } else { THROW_IE_EXCEPTION << "Input blob creation only supports FP32 and U8 precision. Instead got: " + precision; } inputBlob->allocate(); inputBlobsMap[item.first] = (inputBlob); } inputBlobs.push_back(inputBlobsMap); outputBlobs.push_back(outputBlobsMap); } return std::make_pair(inputBlobs, outputBlobs); } ); std::cout << "Blobs initialized once before the loop.\n"; while (1) { ... // Fill blobs with new input values (DO NOT re-create them) for (size_t i = 0; i < exeNetworks.size(); i++) { slog::info << "Filling input blobs for network ( " << topology_names[i] << " )" << slog::endl; fillBlobs(inputs, ioBlobs[i].first); // Only fill the existing blobs } ... }
Error: dlia_infer_request.cpp:53 Number of inference requests exceed the maximum number of inference requests supported per instance
