Hi @jlrainbolt,
Noted on the OS and Quartus version mention, hope all is well from your end.
Back to the issues, I believe you are using the same HLS version 21.4 pro.
My guess is are still suspecting the host machine, by any chances did you managed to try on other version of Quartus and HLS? Or perhaps have another host machine avaialbe to try on the version 21.4 pro mention?
This is just so that we can narrow down the possible issues here.
Hope to hear from you soon.
Best Wishes
BB
Hi @BoonBengT_Altera ,
I have also tried versions 20.2 and 21.2 on the same system. 21.2 has the same problem as 21.4, but when I use 20.2 the error doesn't occur.
I don't know offhand if we have another Linux machine available to install 21.4, but I can find out.
Lacey
