ymiler
Contributor
1 year agoHBM - high band memory
Hi, I tried to generate an HBM memory example module when my device is Stratix 10. I have two projects: One where the HBM is located at the top, and another where the HBM is located at the botto...
AdzimZM_Altera
1 year agoHi ymiler,
I have a few questions in points below:
- What is the device OPN that you used?
- Which Quartus version that you used?
- Are using example design that has been generated from the HBM2 IP?
- For example, this document has provided some guides to create the example design: https://www.intel.com/content/www/us/en/docs/programmable/683379/20-1-19-4-0/generating-the-synthesizable-high-bandwidth-15038.html
Adzim
