Hi @AleCampla,
Thank you for posting in Intel community forum and hope all is well.
Apologies for the inconvenient cause, mind if I asked to provide us which link did you try to download the Intel OneAPI FPGA add-on for us to check further?
My guess is that there might be some inconsistence in the page somewhere that cause this confusion.
Can you please try to access this page here Intel® FPGA Add-on for oneAPI Base Toolkit, and there should be a download button as you scroll down.
The download page will bring you to a page where you will need to select the OS, and you should be able to see the FPGA add-on on the left panel as you scroll to the bottom
Hope that helps.
Best Wishes
BB
Hi !
Thanks for your reply
The page you posted is exactly the link where I am facing this account issue.
E.g, when I click on the "FPGA add-on for custom platforms using Intel Quartus software 21.3 for Linux" at this link here, I get redirected to this other link.
And then I enter the unpleasant "loop" mentioned above.
This happens for all the different quartus versions add-on.
Alessandra
