hoemin's avatar
hoemin
4 years ago
QRD and QRI to solve LLS problem with oneMKL LAPACK gels or gelsy?
Dear Sir/Madam,
I am an Intel DevCloud user base on oneAPI and DPC++FPGA.
The task is to take the Ground-Base TEM (Transient ElectroMagnetic) data in Universal Sounding Format (USF) for geophysical groundwater investigations to convert to matrices (if required) and process with qrd and qri from oneapi-src/oneAPI-samples/ DirectProgramming/ DPC++FPGA/ ReferenceDesigns to solve the Linear Least Square (LLS) problem.
Since unable to find any reference design for LLS for DPC++FPGA, would presume to take the above outputs to solve with LLS LAPACK Driver Routines, but not sue to use gels or gelsy?
Any help that you could provide will be most appreciated.
Thanks. Best Regards
Min HOE
  • aikeu's avatar
    aikeu
    Hi hoemin,
    I will get back to your when I have relevant info to your question.
    Aik Eu
    • hoemin's avatar
      hoemin
      Thanks, Aik Eu. Look forward to hear from you soon.
      Best Regards
      Hoe Min
  • aikeu's avatar
    aikeu
    Hi hoemin,
    I have sent you an email regarding the info I get from my team.
    Aik Eu
  • aikeu's avatar
    aikeu
    Hi hoemin,
    I will close this thread if no further question.
    Aik Eu
  • hoemin's avatar
    hoemin
    Dear Aik Eu,
    I will work on it on this weekend and get back to you for any issue.
    Thanks for your help.
    Best Regards
    Hoe Min
  • aikeu's avatar
    aikeu
    Hi hoemin,
    Any update from the previous comment?
    Aik Eu
    • hoemin's avatar
      hoemin
      Dear Aik Eu,
      I had already replied you on 16th May, 2022, see copy below. Thanks and Best Regards Hoe Min
      Sent: 16 May 2022 16:40
      To: Intel Customer Support <[email protected]>
      Subject: Re: QRD and QRI to solve LLS problem with oneMKL LAPACK gels or gelsy?
      Dear Aik Eu,
      I fully agree with one of your respective team member recommendation to use the existing QRD from FPGA code samples especially this project continues to make use of Direct Programming DPC++FPGA and that is my main objective.
      As I am just a beginner in using FPGA, there are many areas not well understood and much to learn. Appreciate your team member(s) to enlighten me on the followings:
      1) The TEM data in USF format are attached. The attached zip file consists of 3 sets of data (K004 to K006) both in raw.usf and stcked.usf formats were taken from TEM Instrument and already converted to raw and stack data in USF formats.
      2) Presume these USF data can be converted/read/imported directly into QRD of the FPGA code sample? Please provide example or sample code for me to convert/read/import in to QRD. By doing so am I able to get the
      -matrix and
      -vector in order for me to implement 1. perform QRD on
      -matrix to generate
      using the library in code samples, kindly advise the name of the code sample in the library.
      3) After successfully implemented above steps, I then continue to implement 2.Calculate
      using matrix-vector product (this is very trivial) and 3. Back-substitute to solve
      (this is also very trivial).
      Thank you very much for your help.
      Best Regards
      Hoe Min
      Sent: 10 May 2022 09:32
      To: hm3_KL <[email protected]>
      Subject: QRD and QRI to solve LLS problem with oneMKL LAPACK gels or gelsy?
      Hi hoemin,
      I obtained the following info as below:
      According to one of the repective team member, It is much better performance by using the existing QRD from the FPGA code samples than by trying to use the MKL libraries which are not optimized for FPGA.
      Linear Least Squares is used to solve coefficients
      for a system of linear equations when you know
      and have measured ordered pairs
      You can model this as a matrix equation like this:
      Where
      is a matrix
      is a vector
      and
      is a vector
      If you factor
      with QRD, you get
      , and can find
      . Since
      is rectangular (
      ), the resulting
      - matrix will be made of an
      upper-triangular matrix
      , and a
      matrix of 0s. then we can split the vector
      into an n-element vector
      and an
      element vector
      We can find a solution for
      by solving
      ; we can solve for
      using back-substitution since
      is upper-triangular.
      Therefore, to implement a LLS given an existing QRD when the
      -matrix and
      -vector are known, I think you will need to
      1. Perform QRD on
        -matrix to generate
      2. Calculate
      Aik Eu
      ref:_00DU0YT3c._5004UxX9Ie:ref
      • hoemin's avatar
        hoemin
        Dear Aik Eu,
        I am not sure you have received my reply on May 16, 2022 as I received undeliverable message on May 19, therefore attached here again the pdf version of the followings:
        1) Email - hm3_KL - Outlook (Reply sent on 16 May 2022) with USF Format zipped file
        2) Email - hm3_KL - Outlook (Undeliverable message received on 19 May 22).
        Please confirm receipt.
        Look forward to your early reply.
        Best Regards
        Hoe Min
  • aikeu's avatar
    aikeu
    Hi hoemin,
    I get your reply. I was trying to ask about the info to your question.
    I am not able to be certain that there will be answer to your latest questions.
    Aik Eu
  • aikeu's avatar
    aikeu
    Hi hoemin,,
    Aik Eu
