QRD and QRI to solve LLS problem with oneMKL LAPACK gels or gelsy?
Dear Aik Eu,
I had already replied you on 16th May, 2022, see copy below. Thanks and Best Regards Hoe Min
Sent: 16 May 2022 16:40
To: Intel Customer Support <[email protected]>
Subject: Re: QRD and QRI to solve LLS problem with oneMKL LAPACK gels or gelsy?
Dear Aik Eu,
I fully agree with one of your respective team member recommendation to use the existing QRD from FPGA code samples especially this project continues to make use of Direct Programming DPC++FPGA and that is my main objective.
As I am just a beginner in using FPGA, there are many areas not well understood and much to learn. Appreciate your team member(s) to enlighten me on the followings:
1) The TEM data in USF format are attached. The attached zip file consists of 3 sets of data (K004 to K006) both in raw.usf and stcked.usf formats were taken from TEM Instrument and already converted to raw and stack data in USF formats.
2) Presume these USF data can be converted/read/imported directly into QRD of the FPGA code sample? Please provide example or sample code for me to convert/read/import in to QRD. By doing so am I able to get the
-matrix and
-vector in order for me to implement 1. perform QRD on
-matrix to generate
using the library in code samples, kindly advise the name of the code sample in the library.
3) After successfully implemented above steps, I then continue to implement 2.Calculate
using matrix-vector product (this is very trivial) and 3. Back-substitute to solve
(this is also very trivial).
Best Regards
Hoe Min
Sent: 10 May 2022 09:32
To: hm3_KL <[email protected]>
Subject: QRD and QRI to solve LLS problem with oneMKL LAPACK gels or gelsy?
I obtained the following info as below:
According to one of the repective team member, It is much better performance by using the existing QRD from the FPGA code samples than by trying to use the MKL libraries which are not optimized for FPGA.
Linear Least Squares is used to solve coefficients
You can model this as a matrix equation like this:
Where
We can find a solution for
- Perform QRD on
-matrix to generateusing the library in code samples
- Calculate
- Back-substitute to solve
Aik Eu
ref:_00DU0YT3c._5004UxX9Ie:ref
- hoemin4 years ago
Dear Aik Eu,
I am not sure you have received my reply on May 16, 2022 as I received undeliverable message on May 19, therefore attached here again the pdf version of the followings:
1) Email - hm3_KL - Outlook (Reply sent on 16 May 2022) with USF Format zipped file2) Email - hm3_KL - Outlook (Undeliverable message received on 19 May 22).
Please confirm receipt.
Look forward to your early reply.
Best Regards
Hoe Min
