mvemp's avatar
mvemp
8 years ago
Power Monitoring tool - Arria 10 GX board
I am trying to measure power using the Power monitoring tool. I obtain a static power of 14W. When my FPGA is being programmed I see a drop in power consumption (9W). When I run the application, i dont see any changes. Its still 14W. I use FPGA OpenCL SDK to launch my applications.
Anyone uses OpenCL SDK and power monitoring tool? The latency of my application is less than 10ms.
I have attached screenshot of my power results as reference.
  • Hi,
    If the graph is referring to Power it doesn’t make sense. I expect Power to spike during configuration, and drops back down in user mode.
    If it is referring to Voltage, it makes total sense. I expect voltage to take a dip during configuration, (depends on regulator feedback response) it will correct it back to the stable 0.9VCC.
    I would suggest a sanity check.
    1) Scope on the VCC line and see if waveform match the powermonitoring waveform during configuration.
    2) Run an EMIF design. It should consume lots of power. I don’t think running a counter + LED will show any significant change in power. Then monitor your waveform and see if match with the powermonitoring.
    Anand Raj Shankar
1 Reply
  • AnandRaj_S_Intel's avatar
    AnandRaj_S_Intel
    Anand Raj Shankar
