Power Monitoring tool - Arria 10 GX board
- 8 years ago
If the graph is referring to Power it doesn’t make sense. I expect Power to spike during configuration, and drops back down in user mode.
If it is referring to Voltage, it makes total sense. I expect voltage to take a dip during configuration, (depends on regulator feedback response) it will correct it back to the stable 0.9VCC.
I would suggest a sanity check.
1) Scope on the VCC line and see if waveform match the powermonitoring waveform during configuration.
2) Run an EMIF design. It should consume lots of power. I don’t think running a counter + LED will show any significant change in power. Then monitor your waveform and see if match with the powermonitoring.
Anand Raj Shankar
Anand Raj Shankar
