JSYOO
2 years agoPassing PipeArray as template in functor
Hi, I am trying to pass pipeArray through template in a functor. The pipeArray code in the following oneAPI sample directory was used: oneAPI-samples/DirectProgramming/C++SYCL_FPGA/include/pipe_ut...
BoonBengT_Altera
Moderator
2 years agoHi @JSYOO,
The compilation from our end seems to be working and we are able to generate the emulation files for the fpga template.
Based on the error message seen per my understanding you are trying to use the pipe for IO and are facing some issues, there are example design available in the path below:
Perhaps there seems to be some declaration gaps for the pipe, hence would suggest to refer to the sample as a references.
Hope that clarify
Best Wishes
BB
