JSYOO
2 years agoPassing PipeArray as template in functor
Hi, I am trying to pass pipeArray through template in a functor. The pipeArray code in the following oneAPI sample directory was used: oneAPI-samples/DirectProgramming/C++SYCL_FPGA/include/pipe_ut...
BoonBengT_Altera
Moderator
2 years agoHi @JSYOO,
Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
Noted on the error message, may I know what oneAPI version that you are using to compile the mention example? Also what are the compilation command used?
Hope to hear from you soon.
Best Wishes
BB
- JSYOO2 years ago
Hi I attached the CMakeLists and the sample source code.
I run the code on linux and it is running on oneAPI 2024.0 version because this is the only version I download for this machine.
the commands were:
$ mkdir build $ cd build $ cmake .. $ make fpga_emuThe CMakeLists is based on the CmakeList from this repo:
